Richard King
Industrial
Hello all I am new to this forum and need some information on Stress relief in Cast Iron Castings.
I am a machine rebuilder, teach it plus I scrape Cast Iron Master Straight-edges. They were cast in sand and then high temp stress relieved. They will be machined and hand scraped. My question is for many years I was taught to Ring It. The casting that resembles a one sided parallel or some call them camelbacks that look like an airplane wing. Holes in a camel back structure with one side that is flat to .00005"/12".
During the machining and scraping process we hang and "ring" the casting(s) which vary in size of 12" to 72" long and weigh from 12 pounds to 200 pounds depending on lengh, width and thickness.
We hang the casting on a nylon strap or rope and hit it with a rubber, leather, lead, wood hammer or chunk of wood so the casting vibrates and removes any built in stress. I have always been told and re-tell it calling it "Ringing".
I have seen the flat surface I am testing it to a granite surface plate .00005" to .0001". or the flat surface will test flat and then I hang and hit it and it changed. I tap it lightly so it vibrates like a bell or tuning fork. It has helped me for years as a way to relieve small stresses when I am scraping. My question to you is "has anyone ever done this and can you send me or show me here copies of scientific / engineering papers, articles or books demonstrating, discussing or teaching this procedure? Thank You in advance. Richard King
