We have had several failures in our bale press and after some study the loading can be simplified as follows:
Visualize a rectangular plate with a hole in the center. The plate is held down in the center by one nut (super bolt) in our case. There is uniform loading (not necessarily equal on each side) along two opposite sides only. We experience numerous plate failures at the hole where the plate material is at a minimum.
I believe it's a fatigue problem because the load changes every time the press cycles. Is this strictly a bending stress anaylsis (Mc/I) or do I have to use some form of thin membrane theory? The plate in question is two inches thick and there is about 25 ton force on each side of the plate.
This cry for help is from a Mech eng, stuctrually challenged.
