Theophilus
I'm looking for a sort of thermoset, such as unfilled polyester casting resin. At least that's what I think it is.
A client of mine is getting some parts machined from what I believe is a pre-cast resin in rod form (from a vendor in England, I believe). This seems to be because of the nature of the appearance and water resistance of the part.
I need a nice opaque white part, able to put a polished finish on it. I've looked at the thermoplastics available and cannot seem to find quite the right look/feel. (Tried Delrin--nice white, but somewhat translucent.) Normally, injection molded high-volume production stuff is my niche, but this part cannot be feasibly molded while retaining the aesthetic characteristics I need (very thick sections--over 1" in areas--with thin sections in other areas, bad undercuts to be machined in, etc.)
This part will work as part of a premium-line bathing accessory, so it will get plenty of soap and hot water over time. It doesn't need to be terribly accurate (+/-0.015" tolerance is fine) when machined, but needs to be able to sustain decent drops onto the floor without damage.
Can anyone recommend a resin that may work for this machining process, even if somewhat complicated?
One more thing--if it's a cast thermoset, we can cast the rods ourselves, but cannot use the material if there is a significant risk of air bubbles within the rod to be machined.
Jeff Mowry
Reason trumps all. And awe trumps reason.
Jeff Mowry
