Hello all,
Please see the attached image to visualize the issue.
First image: An assembly consisting of a large block and a small block. The assembly contains 1 constraint which is a Touch Align constraint between the large and small block. When using the Move Component command on the small block, it moves independently from the large block, as expected.
Second image: The same assembly as the first, but contains an additional parallel constraint between the large block and the YZ datum plane. Here is where the problem happens: when using the Move Component command on the small block, both the small block and the big block move together! This is not what I want and is totally illogical. There is no constraint in the assembly which dictates that the small block is "glued" to the big block. I want the small block to move independently from the large block.
What should I do to change this behavior?
NX8.5 Win7SP1 64bit i7-3770K@4.3Ghz 16GB Quadro2000
