Sounds like a mix in Construction Types - you might want to check with your Architect as to the intended building Type/occupancy requirements as you are mixing flammable building elements with non-flammable.
If you are type 5, I believe you can use the steel, but, but if you are a lower type number, the wood walls may not be allowed.
