Hello, in the image below, we can see the model with support conditions. At its right you can see the result for self-weight analysis. We can see that Rafter001, as expected, only has vertical reactions. Therefore, the design forces will be V and M only, right? but for Rafter002 to 011, where we have now a ridge beam, the reactions changed, and now they also have Normal force, causing a reaccion outwards pushing the below support outwards.
Is there something wrong with the model? why, when we add a ridge beam there is horizontal reaction, and the ridge beam is bent outwards (towards -Y) ?
Thanks a lot for any input.
M.
M.
