GearsNsparks
Howdy,
I'm looking at a bracing connection for some existing mining equipment structures. There is a nominal gap of 1/2" between the end of the beams and the connection to the flange of the column. Is this a common practice? Is it intended to help with manufacturability (getting the columns spaced exactly as intended without letting the cut beam length govern the spacing?). Or does this allow some sort of rotation to assume a pinned connection in structural analysis even though it looks like you could still transmit a healthy moment via the top and bottom beam flanges?
Thanks for any insight.
