Steel column to concrete block wall air seal
Alan CA
95
Hi everyone,
I have this existing building with above-grade exterior concrete block walls and steel columns. The steel columns werr not air sealed and you can feel air draft through at the web and flange corner. The attached sketch illustrate the situation.
How do I air seal the gaps between the columns and the block walls? What details and materials would you recommend?
This is great, thank you very much.
Gaps I have are almost 1 in. in width.
What compressible fillers would you think I'll need?
I would think something like neoprene or something of that ilk. If it is to be clad with a finish, you might consider a product like blueskin.
If you use urethane foam, be aware it is not particularly UV resistant, painting after applying prevents UV ageing.
I'm guessing one side is exterior, and one is interior.
Goes the the exterior side get wet from weather?
I'd seal the outside flange first to prevent water ingress, damage and corrosion, and if objections to drafts continue the inside flanges as necessary.
When there are big differences in outside and inside temperatures I'd expect a noticeable convective loop of cold air flowing down the warm wall. The steel column with exposed flanges is pretty effective heat exchanger. Residential window "draft" complaints are sometimes are based on convective loops.
