kevcha
Petroleum
- Oct 22, 2015
- 1
I was wondering if anybody could help me with a query. A number of years ago I worked within the aerospace manufacturing industry and remember that our drawings had a spec/standard in the title block that when reviewed told you general tolerances for linear dimensions and hole features (drilled holes, tapped holes, rivet holes etc) this was used if a tolerance was not specified on the actual drawing. Problem I have is that a customer is using ASME Y14.5 and is using trailing digits to specify a tolerance. Problem with this is that when drawings have been updated to CAD drawings a simple 3/8" thread depth now becomes 0.375" is subject to 3 decimal places tolerance which is +/-0.005". Is there something within ASME that does what I can remember from aerospace?
