Hi
I am modelling a 6 storey building using Etab (21m high). I modelled the stair walls and core walls using wall pier and spandrel around the openings to take vertical and lateral load (wind and earth).
Please see the attachment for the load applied on the wall pier at Level 1. The moment from earth load (91KNm) is quite high for pier (250mm wide x 150mm thick).
Heavy reinforcement must be used in this pier.
My question:
Any thing wrong in the way I modelled and give this load to the wall pier ? This load is reasonable ? If yes, then use heavy reinforcement in this pier.
My question:
