Bridgegirl67
I will provide a little info and then follow with my question..
I have a job that requires a temporary sheet pile retaining wall (possibly a tied-back).
My soil is generaly a light clayey silt with traces of fine sand and gravel (For the most part). I have originally assumed there are cohesive properties (enough to effect the wall)
I have calculated my Active (Pa) = 0.070 ksf and my Passive (Pp)=8.46 ksf with the information provided by my soil borings.
My cohesion (C) for my active I have as 0.49 ksf and 1.26 ksf for my passive.
The Retained height (H) is 16.0' and I am assuming that my soil is 0.120 kcf.
When I go to check for my stability (Ns), do I use ...
a) the C from my active soil
b) the C from my passive, or
c) the average from them both???
Also, would I be better off assuming NO cohesive properties for the retained and resisting, recalculating all of my pressures and approaching it from that angle.
**Please note I assumed my angle of internal friction (28 deg),my friction angle (between sheet pile & soil @ 14 deg), my wall is vertical and the backfill is horizontal.
I am new(er) to design and could use any and all guidance/advice/answers that I can get.
Thank you for all of your assitance (in advance)!
