Square graph in excel?
Tomfh
3,591
Is there any way to force excel to draw the X and Y axes at the same scale?
thread770-141275
Open a macro
Insert the following:
Selection.Width = 450
Selection.Height = 450
Select the chart
run the macro
TTFN
I assumed the original poster wanted a 1:1 aspect ratio. Can you clarify. I don't think IRStuff's code will accomplish this.
The default plot area is not square on the display. The code basically stretches the plot area to be square on the display. The actual values to be used will depend on your display resolution.
TTFN
But a square plot is not the same as a 1:1 aspect ratio between X and Y plot units.
For example if I plot y=x it would be 45 degree from horizontal with 1:1 aspect ratio.
But if X axis is 0-10 and Y axis is 0-100, then a plot of Y=X will be about 10 degrees from horizontal.
Right-click on the axes, select "format axis" and set the scales to the same value.
"...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail."
Wm. Phelps Eno, ca. 1928
It looks like you'd need to use IRstuff's macro as well for that to work. Any other ideas?
thread770-141275
Manually you can quite obviously control whatever you want by manually resizing the chart area with the mouse and adjusting the graph axes. One problem – every time you change the data beyond the bounds you will again have to manually adjust the graph axis.
There was a vba solution I posted in the linked thread 3 Dec 05 which met my needs very well (one execuation of the macro auto-scales and sets 1:1). It was based on another posters information prior to that in the thread. Subsequent modification was made but I don’t know what it did.
Also at the end of the thread, Yakpol had a suggestion for creating a phantom series that when autoscaled would accomplish the same thing. I never tried it.
