Spreadsheet not allowing to inserts a column
GPowers2
Aerospace
May 8, 2003
98
people,
I have a spreadsheet that was created in Excel 2003 and am now using Excel 2010
the spreadsheet refuses to allow me to add a new column and stops at IV with no columns
appearing after that .... that column IV also has a drop shadow which indicates to me that it
has some characteristic added that prevents activity beyond this column,
I do get dialogue which i have tried to make sense off but still struggling
something simple i am sure
thanks in advance for your help
regards ... gary
A live worksheet would be more useful. The max is XFD in my version
TTFN
faq731-376
7ofakss
Hello IRstuff
content of spreadsheet maybe a bit sensitive, costs etc. having said that I could,
and would have stripped out this info if not for the fact that i have managed to fix it
story goes that EXCEL 2003 culd only manage 256 columns ( a limit i had reached )
Although I am using EXCEL 2010 with many more columns available i simple had not
done a SAVE AS to the new rev ( .xlsx) I had continuly been saving to original format 2003
and so up against the 256 limit.
I saved to .XLSX and all is good ..
regards .. gary
When you open an old-format Excel file (.xls), Excel keeps it in compatibility mode to mimic the 2003 version. This might work: Do a save-as, and choose the new format (Excel 2010 spreadsheet, or .xlsx). Re-open the new file, and you should have the ability to insert columns and go waaaaayyyy past column IV. Might not work, but it's worth a quick try.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Also, you can always try a simple copy & past of the old spreadsheet into a new one. Simply right click the space above Row 1 and to the left of column A and copy the sheet & paste it in a new spreadsheet. Save in 2010 format and see if that works.
GPowers2, It looks like you beat me by seconds in posting.
Glad you got it fixed!
Best to you,
Goober Dave
