Split Body not working in NX11
bongoman
78
When I try to use split body in NX11.0.1.11 MP1 I get an error message "A deleted or invalid class id was used". Then nothing. Anyone run across this one? So far everything else seems OK.
Rick D
Win7 64 bit w/NX9.0.3.4 MP9 and NX10.0.3
Vericut 7.4
Try running 'Part Cleanup' on your model and then try again. If this doesn't help, contact GTAC.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
Thanks for the quick reply John. Good to hear from you. Unfortunately that didn't work so I will contact GTAC.
Vericut 7.4
I was have that same problem.
I was install nx 11 with "customize" option and Split Body did not work.
I was uninstalling NX and install with "typical" option and now this operation work.
I checked it at 3 diffrent machnines.
Best regards
Michał Nowak
Hi Michal,
I ended up uninstalling and re-installing NX11 with "typical" as well but did not use "customize" the 1st time. It is working now. Contacted GTAC but they could not help me.
Rick
Win7 64 bit w/NX10.0.3.5 MP14 and NX11.0.1.11 MP1
Vericut 8.0
