PV design Engr
I have a horizontal vessel and on which a tower is mounted. The tower mounting flange is a male female type app-2 designed flange. The flange on the horizontal vessel is female type with groove depth of 5 mm. The raised face in male type flange is 5mm. We have used 4.5mm thick spiral wound gasket in this case. Flange ID is 1700mm. Manufacturer by mistake has procured 6.35 mm thick gasket. The equipment has to be hydrotested next week. Can i accept 6.35 mm thickness gasket for 5 mm grove considering that fact that the gasket in compressed state will be aroud 4.5mm. Does any one has previois experience on this issue
