Special Inspections - Small Expansion
FEM4Structures
48
I am dealing with small building remodel design. Basically adding an overhead door. Site area 20’x11’. Is anyone aware of such a code clause which may forego the need of special inspections for a small additions projects?
Thanks,
FEM4Structures
When have special inspections become a requirement for projects?
I thought it was up to the EOR of the building inspector.
The code states a minimum area requirement, it should be under the exceptions section of Special inspections in the IBC.
Sorry don't have it handy to point to exact location
It talks about exception for projects of small nature leaving the decision to EOR. Does not give the hard square footage to consider a project to be small.
Thanks,
FEM4Structures
You made me look it up. And I confirm that the IBC is not specific. It says that they are req'd if that plans must have an A/E Seal. It seems that my local jurisdiction has a statement of special inspections form that we must use and it has a 'Required base on Group and Area) Mercantile must be 5000 sq ft.
Sorry for the confusion, it seems like it is your decision and the BCO.
my experience is that you are at the mercy of the local jurisdiction.
