alwayslearning
Dear All,
1) Does a copper cable (9 mm od- made of multi core fine drawn wires) riding freely on a rotating eequipment shaft (made of Forged Alloy Steel) lead to sparking?
2) Is it possible that the above cable (riding freely on the rotating shaft) can cause any grooves or damage to the shaft.
Let me explain this "riding freely" more clearly: We tied one end of the copper cable to the turbine casing and let the cable (about a foot long) rest freely on the shaft of a condensing steam turbine shaft to effectively "ground" the
shaft to eliminate the static charge generated. Having done this we in the plant are going through a debate about the safety aspect.
Is it at all possible that a spark is generated by the contact of the copper cable and shaft? Where in literature can i find a mention about such a possibility? Does NFPA mention any possibility of spark occurence due to contact of copper and steel etc.?
Any help would be most appreciated. Thanks
