what creates stainless steel 304 wire spring back?
pfhelicoil
what creates stainless steel 304 wire spring back is it tensile being too high or chemical composition?
Are you talking about spring back in forming?
If so then it is likely that you are forming it wrong, not enough over-bend.
It is easy enough to check the tensile strength.
The operator over bends just slightly to mitigate spring back, it depends as Ed said tensile strength or equivalent hardness. .it has to be developed to obtain correct dimensions.
If you are refering to wire, it is most likely cold drawn and easily in the 1/2 hard or higher condition and a very high yield strength. It cannot readily be additionally cold formed.
Hard SS wire is regularly formed on various spring forming machines.
If you are accustom to forming steel spring wire the SS will have more spring back.
Additionally just add to Ed's comment.
It also depends on the geometry of the component. And how it is manufactured.
And the heat treat of the wire. Use annealed wire if you want less spring back.
Yes, a higher tensile strength will mean more spring back. Fully annealed wire will spring back less than 1/2 hard or full hard or spring temper wire. As Ed said, stainless wire also springs back more than carbon steel wire due to differences in work hardening between the two materials.
Just a word of caution.
The terms 1/4 hard, 1/2 hard, full hard and so on only apply to flat rolled product.
Wire has it's own specifications (such as ASTM A313) and the specified tensile strength is a function of the wire diameter.
We used to draw 304ELI to 500ksi tensile, but it was 0.004" diameter.
Ed... how common is it to use 304 in-lieu-of 302 SStl for spring/music wire... or is it no big deal [same-same]?
They are interchangeable unless you need 302 class 2 which is stress relieved.
Stress relieving high strength wire generally increases the UTS.
The alloys listed in A313 fall into three broad groups.
305, 316, 321, and 347 are slightly lower strength (for 0.060" about 250ksi)
17-4PH and 455 have their own properties.
All of the rest of the 200 and 300 series alloys have their own tables also, but they are all very similar with a UTS of about 295ksi for 0.060" wire.
