Spaceball 4000 on 64 bit
ryno23
I have a spaceball 4000 serial port. I am trying to get it to run on a new 64 bit machine. I have downloaded both the 2.8.2 and the 3.6.6 drivers. I can't seem to get it to do anything. it beeps twicw when the machine starts,,,and that's it.Thanks for the help
You have to install the current 3DxWare, but you have to install the OLD SW drivers. I went through this at my last job. To tell you the truth, just buy a new one. I spent hours upon hours fighting with the 4K and the computer and it's not worth the wasted man-hours.
SW2008 Office Pro SP3.1
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot/SpaceNavigator
I spent quite a few hours trying this as well.
The only solution I know of - Spaceball 5000 USB. with driver 3.6.6
There is no way 64-bit would take 4000FLX. At least I couldn't find it...
If you want to go back to 32-bit machine and use your 4000FLX with SW2008 you need to install 3DxWare 2.8.2 and Swx add-on from 3DSoftware 3.6.4
Hope it helps.
