Thanks wes616,
Your reply is very interesting and I appreciate your response. I can't really put my finger on what is making me leery about this except that I went through all this 15 years ago with 2D CAD, with software that really wasn't that good, at least at that point in time. I am suspicious that Pro-E and Solidworks aren't there yet either when it comes to building structures.
For example, you could design a house with Solidworks. Your model could contain every stud, cut piece of drywall, wire, wire nut, fixture, and so on. However, when you run the wiring through the walls you need holes in the studs creating another part number. Instead of having a pallet load of standard studs all the same, you have perhaps another 100 part numbers. Each part number (stud) would need to be drilled per a drawing, identified and deleivered to the point where it would be put in. My point is that in my experience a lot of what is done currently in structural steel and building construction is more like a schematic or a simplification rather that a detailed drawing. I'm not sure I want to do this with solid modeling software.
I know that my house example is an oversimplification, and I am not experienced with Solidworks specifically so I can't really make a judgment at this time. Just asking for input and comments if anyone is interested.
Thanks,
-Mike
