I am learning about car's suspension, and there are many sites, none that I found has a good explanation, also names of the suspension are not the same from site to site.
But I really don't understand movment of coil spring solid axle, because from the picture I can see say that both wheels can move only the same way, because otherwise if one will move up and other down, the axle should move right or left, because mounting of the axle can't move vertical up and down but it swings in arc, so if the left wheel moves up it should also steers left, and right wheel will then move down and right. And another misunderstanding about solid axel is that if it swings up or down it shoul rotate where carrier is mounted to the axle.
Then aslo I don't understand how can you turn a front wheel if (according to the picture) shock absorber is mounted stiffly to the "wheel holder" (don't know the word)
.jpg)
