josemanuellodoso
New member
I have a joint between a fitting (modelled by tetra10 elements) and a spar (modelled by cquad elements) in which each fastener is modelled by:
-RBE2 attaching 4 nodes of the fitting to central node 1 (DoF 123456)
-CBUSH between central node 1 and central node 2 (the same node duplicated). (PBUSH properties according to the fasteners size, material... in the 6 DoF)
-RBE2 attaching 4 nodes of the spar to central node 2 (DoF 123456)
When a run a linear analysis everything looks like Ok, loads in CBUSHs have an adequate direction and value. At the same way, stresses at fitting and spar elements have reasonable values.
However, the model has large deformations and then I have decided to run a sol 106 to obtain more accurate results. The problem is that when I do this, nothing has sense: the loads in the CBUSH have random direction and induce stress peaks in the elements caught by the RBE2s.
I have though that this could be because RBE2 and CBUSHs don't have "non-linear capacity", and then rotations induced by them in the elements of the fittings and spar are wrong, producing these peaks of stress. Any idea?
Thank you
Thank you
