With all things I have done as an engineer, I have never sized a psv.
This psv is on the discharge of a 2x1 centrifugal pump that circulates hot water in a closed system to provide heat to a couple of jacketed vessels then back to and through a small hydronic boiler. Temp of product is 45 degrees C +/- 5 degrees C. Psv on the boiler is set at 45 psi.
How do I size and select the psv on the discharge of the pump?
I suscribe to the statement that the only dumb question is the one you don't ask. I'm asking.
Thanks,
9751jld
Thanks,
9751jld
