VTStructures
Hi All,
US based, designing with AISC 360-16 (15th Edition). I just recently started using RISA Connection to help with steel connection design efficiency. I'm still in the process of vetting the calcs, and came across an unexpected result using single plate connection to a column. When connected to an HSS wall, the software automatically treats the connection as the Extended configuration. This causes the program to design the bolt group for the full eccentricity from the face of the column to the bolts. If I switch the column to a wide flange (flange or web connection), then it allows for the Conventional design checks, which uses half of the actual eccentricity per AISC table 10-9.
Now, it makes some sense to me that the more flexible support condition of the HSS wall could allow for additional rotation. This in turn might justify designing the bolt group for the full moment. I was wondering if anyone had any references that indicated you had to use the Extended design checks when connecting to face of HSS. I don't mind erring on the conservative side, but there may be a time where I have to explain to the EOR/Contractor why I am calculating a lower shear capacity for a standard connection than is listed in the tables in the manual.
(For what it's worth, I have also reached out to RISA support and am waiting to see if they can clarify).
Thanks all!
Thanks all!
