ToadJones
- Jan 14, 2010
- 2,299
For a single bolt connection....say a tension/compression connection of plate sandwiched b/t two other plates with only a single bolt(in double shear) going through all three plates connecting them...would this be design as a "pin-connected member" per Section D5.1 pg 16.1-28 in the 2005 code as well as a compression element per J4.4 pg 16.1-113 ?
Shear and block shear of connection elements doesn't seem to fit here.
Connectegr, you out there?
