See attached JPEG, this is a simple and interesting engine that works off a bycycle pump. I am struggling to find the correct constraint that will allow the piston to move in the chamber. As you can see a simple align option does not work as the piston not only moves in and out but also rotates. This is made possible as the piston face is only 0.5mm thick.
I can get the engine to work with a pump but not in NX6. Any Ideas would be gratfully received.
