WILL21
- Jul 18, 2003
- 1
OUR MUNICIPAL WATER SYSTEM TREATS THE WATER WITH SODIUM HYPOCHLORITE FOR DISINFECTION AND A POLY-ORTHOPHOSPHATE (0.9 MG/L DOSE)TO SEAQUESTER IRON AND MAGANESE AND TO ENABLE LEAD AND COPPER CONTROL. pH IS 7.2 WITH LANGLIER INDEX OF -1.0.
A NEW AND VERY EXPENSIVE HOME HAS LIMESTONE FLOORS IN THE SHOWER STALLS. THE SHOWER STREAM IS 10-20 GPM DELUGE. THE WEEP HOLES FOR PAN DRAINAGE ON THE BRASS DRAIN FITTING ARE PLUGGING WITH CLOUDY WHITE HARD DEPOSIT AND HAS LINED THE INSIDE WALLS OF THE 3" DRAIN FITTING WITH 1/2" THICK DEPOSIT.
IS THE POLY-ORTHOPHOSPHATE CHEMICALLY REACTING WITH THE LIMESTONE TO CAUSE LEACHING AND DEPOSIT?
OR ARE THERE OTHER WATER QUALITY PARAMENTERS THAT WILL HAVE THIS EFFECT ON LIMESTONE?
