Hi all, does anyone have resources that would be useful in designing (or not designing) a water main through an abandoned septic drain field?
I'm currently scoping a project in WA that is supposed to loop a water main, but the existing dead end is locked in by buildings and an abandoned septic drain field. The field was abandoned sometime before 1998. None of the usual reference documents contain any standards on running a main through an abandoned drain field (although they do require a minimum of 10' of separation from an active one, which is not feasible on this project).
Any tips, backed by some references, would be very helpful!
TIA
TIA
