NewbieStruct
I am working on a renovation of three story wood building. The owner wants to remove a load bearing wall on the 1st floor. This wood stud wall has load bearing walls stacked on top of it (at the 2nd floor and third floor levels). In theory, if I add a steel beam at the locations with columns on either end, I would be able to carry the load back to the existing foundation. (the foundation needs to be increased in size).
However, I am unable to understand the way the construction sequence would be. How can the contractor shore the trusses that are bearing on the 3rd floor and at the roof? Does he need to build a shoring mechanism all the way up to the roof?
