I am doing a project where I am strengthening an existing structure that is insufficient. The current structure utilises a channel for a beam and as a method of strengthening it I am fastening an addition channel to it back-to-back (webs vertical).
I am struggling to visualize how to calculate the spacing of the fasteners, I have reviewed the methods of fastening together flanges to webs etc using Tau = VQ/I.
The main part I’m struggling with is to calculate Q as the sections as the sections are side by side and there is no eccentricity of the sections in y direction. Is my method of approach correct or should I calculate the shear stress in the section at the bolt location using sigma = M/Z and calculate a force on the bolt from there?
Also is there any pros or cons to fastening at both the top and bottom of the web as opposed to just fastening in the centre of the web?
I have attached a rough drawing to illustrate
Thanks in advance
Thanks in advance
