DAVIDSTECKER
I am working on the design of an output shaft for a gearbox and need some input about a type of fillet for the step between two different diameters.
I know the general rule is to use as large of fillet as practical, but some time ago I ran across a design that actually plunged into the smaller diameter then went straight up the face to the larger diameter.
This was supposed to be better than just a fillet in the 90 deg. step.
Does anyone have experience with this practice and is it the better way to go?
Best regards, David
Best regards, David
