R
rullan
Guest
When I go to print a drawing, I have to go through the process of configuring the model size, page size, etc. I know I can then save that configuration for future use in the directory from which I'm working at the time. If I decide to change the page size, I have to reconfigure the print set up.
Is there a way to set up ProE so that it would recognize a specific configuration automatically, based on the page size?
For example, suppose I configure the print set up for an A sized drawing in directory X, then later I move to directory Y and go to print a different drawing in A size. Rather than go through the process all over again, can't ProE see that I'm trying to print A size and automatically pull the configuration for an A sized drawing? The same for B or C sizes?
