I have a question about a thin walled aluminum bearing housing (semi rigid?) in regards to feature size and form.
My application requires a tight tolerance for the bearing housing bore in which a deep groove radial ball bearing will be installed via a press fit. These bearings are custom made with special internal geometry for our specific application. Likewise, the housing size and tolerance has also been designed specifically for the application and the custom bearing. Because of the tight size tolerance for the housing, we are struggling to meet the Rule #1 principle and still be cost effective for my application.
In this example, we have two bearing housing bores on each side (horizontally opposed) with the same size, location, and form tolerances specified. Each bearing housing bore is identified as Datum A and Datum B respectively.
Details:
Bearing Housing ID Feature Size & Tolerance: ∅30+/-0.01
Bearing Housing ID Feature Position: [POSITION][∅0.1][A-B]
Bearing Housing ID Feature Form Control: [CYLINDRICITY][0.005]
*ALL DIM ARE MM*
Geometric Dimensioning and Tolerancing Standard: ASME Y14.5M-1994 (ASME Y14.5-2009 can be used if justified)
Currently we our suppliers are capable (Ppk>1.33) of making the feature within the size tolerance using the least squares method. However, when Cylindricity (form) is checked, we can clearly see that the suppliers are only capable to around 0.02. This also shows the same violation of Rule #1 when the minimum circumscribed cylinder and maximum inscribed cylinder is reported.
During development testing and evaluation combined with warranty data from systems in operation, the data shows that the current parts my company is receiving and selling are meeting customer needs. Therefore, as the designer, it is my responsibility to document the part's requirement to satisfy the customer need. I believe this evidence clearly indicates that the current specification is too restrictive.
I would like a way (as legal and standard as possible) to decouple the size and the form while still maintaining orientation of the feature.
I have searched somewhat extensively in this forum about this situation and have found a few useful threads:
In the above threads, you can see several ways that this might be accomplished. However, none are clearly straight forward according to the ASME Y14.5M-1994 or even the ASME Y14.5-2009 standards. Here are a few options that I can see might work. I would like some feedback about which option might suit my situation the best.
OPTION 1: Per ASME Y14.5M-1994
Use a combination of average diameter and form control to purposely violate Rule #1 per section 6.8.3 AVERAGE DIAMETER and as shown in FIG. 6-53. However, since this bearing housing is semi rigid (not flexible, but still can be deformed somewhat), do not use the Free State Variation symbol (F) in the FCF of the form control for Cylindricity. This is because the rest of the part is assumed to be measured in the free state and I do not have any constraint requirements for measurement of the bearing housing.
In this case does the size need to be expressed using the limit dimensioning technique as shown in FIG. 6-53 or is it possible to also use plus minus tolerancing for this case? For our use, specifying a target for feature size is useful for communication, but also calculating capability.
OPTION 2: Per ASME Y14.5-2009
Use the Independency symbol (I) per section 3.3.24 combined with using the text AVG on the feature's size specification. Then specify the form tolerance independent of Rule #1 as needed.
OPTION 3: Per ASME Y14.5M-1994
Use a combination of size tolerance and form tolerance that violates Rule #1 as needed, but use a note under the feature's specification or a flag note in the drawing to communicate that Rule #1 does not apply to denoted feature.
There might be other options available that I am not thinking of as well. Any suggestions or feedback would be helpful.
Thanks.
Details:
*ALL DIM ARE MM*
Thanks.
