Self Drilling Hollow Bars to Stabilize a Stone Retaining Wall
crcivil
MX
I've submitted a proposal to stabilize a gravity stone retaining wall 13' tall, 450 yd long, 25" width on the top, batterd towards the backfill, and with a width of 8' at the bottom. The foundation rests on soft clay soil, and the backfill material for the wall consists of coarse gravel (ballast) partially saturated.
There is a row of concrete small apartments resting on this backfill all along and just a few feet away from the wall. This wall exhibits horizontal cracks and tilting (3-4" from vertical) in some sections and I have proposed the owner to restrain it by means of two rows of 9 m and 7.50 m long soil nails employing 38 mm hollow bars with a 3 1/2" drill bit for a simultaneous drill and grout operations.
How should I go about drilling a 3.5"-4.0" borehole through a 8-feet width stone wall with a top hammer track drill without disturbing the structure before I start drilling and grouting through the coarse gravel backfill?
Best regards
Coring would be better than percussion drilling
What are your thoughts about the proposed solution to stabilize the retaining wall?
Thank you Ron, that's what I thought too but I'm not sure about the kind of rig I should use to go through such a depth
I had a job fixing a stone wall around a prison that has been built by inmates years ago. It was only a wall, but not retaining anything. The wall was built as weak as possible I suppose in hopes of allowing a prison escape break out some day. However, it was falling apart, tipping and supported masonry structures some 20 feet high. It was repaired by injecting a cement grout, due to it being porous allowing that injection. Just passing this on as a possible option.
Thank you oldestguy, it is well appreciated.
crcivil....most commercial concrete coring firms have the capability to core through depths that you've described. They will return incremental cores, but I take it you're not interested in the core, just the hole.
How about the rock samples taken for a mining project? I think they can employ track drills for that job, but what kind of bit to be used with the top hammer for my purpose? I will also ask for an estimate from a concrete coring company as you've suggested Ron. Regards.
DTH drilling using a Stenwick rig with a carbide button drill, would that damage the wall? Boreholes every 1.80 m, 4" diameter, 2.40 m long, through a stone wall.
Carbide button bit I meant
If the stone is loose with a lot of seams you will have a problem drilling without a temp. casing. A DTH drill with a casing would be your best bet in my opinion.
