Here is something I am working on that may be of use:
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Utilities
Imports System.Collections
Imports System.Windows.Forms
Imports System.Collections.Generic
Imports NXOpenUI
Module NXJournal
Dim theSession As Session = Session.GetSession()
Dim theUFSession As UFSession = UFSession.GetUFSession()
Dim workPart As Part = theSession.Parts.Work
Dim UserInputNumber As String
Dim lw As ListingWindow = theSession.ListingWindow
Sub DoIt()
Dim allComps() As Assemblies.Component = Nothing
Dim CompCounts() As Integer = Nothing
getAllChildrenPacked(workPart, allComps, CompCounts)
For ii As Integer = 0 To allComps.Length - 1
Echo(allComps(ii).DisplayName & " X " & CompCounts(ii))
Next
End Sub
Sub getAllChildrenPacked(ByVal assy As BasePart, ByRef children() As Assemblies.Component, ByRef counts() As Integer)
Dim theChildren As Collections.ArrayList = New Collections.ArrayList
Dim theCounts As Collections.ArrayList = New Collections.ArrayList
Dim theChildNames As Collections.ArrayList = New Collections.ArrayList
For Each child As Assemblies.Component In getAllChildren(assy)
Dim thisChildName As String = child.DisplayName
If theChildNames.Contains(thisChildName) Then
theCounts.Item(theChildNames.IndexOf(thisChildName)) = theCounts.Item(theChildNames.IndexOf(thisChildName)) + 1
Else
theChildren.Add(child)
theChildNames.Add(thisChildName)
theCounts.Add(1)
End If
Next
children = theChildren.ToArray(GetType(Assemblies.Component))
counts = theCounts.ToArray(GetType(Integer))
End Sub
Function getAllChildren(ByVal assy As BasePart) As Assemblies.Component()
Dim aChildTag As Tag = Tag.Null
Do
theUFSession.Obj.CycleObjsInPart(assy.Tag, UFConstants.UF_component_type, aChildTag)
If (aChildTag = Tag.Null) Then Exit Do
Dim aChild As Assemblies.Component = NXObjectManager.Get(aChildTag)
theChildren.Add(aChild)
Loop
Return theChildren.ToArray(GetType(Assemblies.Component))
End Function
Public Sub Main(ByVal args As String())
If workPart IsNot Nothing Then
DoIt()
UserInputNumber = NXInputBox.GetInputString("Enter Partial Text of Components To Load", "Text", "")
If UserInputNumber = "" Then
Exit Sub
Else
Dim allComps2() As Assemblies.Component = Nothing
Dim CompCounts2() As Integer = Nothing
Dim theFoundKids As Collections.ArrayList = New Collections.ArrayList
getAllChildrenPacked(workPart, allComps2, CompCounts2)
For Each allComps3 As Assemblies.Component In allComps2
Dim nameCount As Integer = allComps3.DisplayName.ToString.Length
Dim strippedName As String
If nameCount > 8 Then
strippedName = Right(allComps3.DisplayName.ToString, (nameCount-5))
End If
lw.Open()
If strippedName.Contains(UserInputNumber) Then
Dim componentsToOpen1(0) As Assemblies.Component
Dim component2 As Assemblies.Component = allComps3
componentsToOpen1(0) = component2
Dim option1 As Boolean
option1 = theSession.Parts.LoadOptions.UsePartialLoading
lw.Open()
lw.WriteLine(component2.DisplayName.ToString+" component2 Name")
Dim openStatus1() As Assemblies.ComponentAssembly.OpenComponentStatus
Dim partLoadStatus1 As PartLoadStatus
partLoadStatus1 = workPart.ComponentAssembly.OpenComponents(Assemblies.ComponentAssembly.OpenOption.WholeAssembly, componentsToOpen1, openStatus1)
theFoundKids.Add(allComps3)
lw.WriteLine(componentsToOpen1(0).DisplayName.ToString+" componentsToOpen1")
lw.WriteLine(openStatus1(0).ToString+” openStatus”)
partLoadStatus1.Dispose()
If openStatus1(0).ToString = "CouldNotOpen" Then
MessageBox.Show("Unable to load, please load manually")
End If
End If
Next
'-------------------------Error Message if None Found-------------------------------
If theFoundKids.Count < 1 Then
MessageBox.Show("Component Not Found!")
End If
'-------------------------Show Components Getting Loaded---------NOT DONE YET-------------------
lw.WriteLine(theFoundKids.Count.ToString+" theFoundKids")
lw.WriteLine(UserInputNumber.ToString+" UserInputNumber")
lw.Close()
End If
Return
End If
For ii As Integer = 0 To args.Length - 1
Echo("Processing: " & args(ii))
Try
Dim loadStatus As PartLoadStatus = Nothing
workPart = TryCast(theSession.Parts.OpenBaseDisplay(args(ii), loadStatus), Part)
reportPartLoadStatus(loadStatus)
DoIt()
workPart.Close(BasePart.CloseWholeTree.True, BasePart.CloseModified.CloseModified, Nothing)
Catch ex As NXException
Echo(" " & ex.Message)
End Try
Next
End Sub
Sub Echo(ByVal output As String)
'theSession.ListingWindow.Open()
'theSession.ListingWindow.WriteLine(output)
'theSession.LogFile.WriteLine(output)
End Sub
Sub reportPartLoadStatus(ByVal load_status As PartLoadStatus)
If load_status.NumberUnloadedParts = 0 Then
Return
End If
Echo(" Load notes:")
For ii As Integer = 0 To load_status.NumberUnloadedParts - 1
Echo(" " & load_status.GetPartName(ii) & " - " & load_status.GetStatusDescription(ii))
Next
End Sub
Public Function GetUnloadOption(ByVal arg As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
