So if you are connecting an addition to an existing building what is the conscensus on the use of the Response Modification Factor and the system Overstrength Factor? By that I mean if the existing, older building, has different factors than the new addition what Factors would you use for the building as a whole, existing and addition as one building? It is the intent to not seismically separate the two.
