pmarc
- Sep 2, 2008
- 3,227
This may be a stupid question, but I will try:
Let's say a part similar to the one shown in fig. 4-26 of Y14.5-2009 has to be inspected and there is a physical datum feature A & B simulator available in order to define proper DRF and to mount the part on it during a check of positional callout on two M20 threaded holes. There is only one part manufactured and will be no more. Imagine also the datum feature simulator is perfect, so there is no chance that bad part will fit on it and that good part will be somehow rejected.
Knowing all of that, how should inspector proceed if it occurred that as-produced part did not fit to the simulator, or in other words if the secondary datum feature pattern of 4 holes did not meet positional requirement wrt primary datum A? Should the inspection process be stopped immediately and the part sent to re-work (if possible)?
Any suggestions, thoughts to share?
PS.: This has nothing to do with the threads about extention of principles and IT# in ISO FCF's. At least at the moment I see nothing common
