Scale format
Lars1978
327
Hi All,
How can I change te scale format of mij view. Please see the pic's below. I'v typed 1:30, the display of my view gives 0.0333:1.0. When I open the view style dialog again the scale format also say's it's: 0.0333:1.0 in stead of het more "readable" 1:30
I understand it's the same scale vallue expect it doesn't look good to me. And yes I'm aware of the fact that im not using "standard" scale vallues :)
I'd like just to show the drawing view label to show as 1:30 and also in the dialog box this should be nice, if not common sense :)
Any suggestions?
Lars
NX12.0.1.7 native
Solid Edge ST10
Inventor
Lars
NX12.0.1.7 native
Solid Edge ST10
Inventor
That setting is for the view scale and not the view label format - you need to look down that list & expand the Section area. Under that should be the view label settings where you can turn the label & scale off & on as well as set the view scale value format (Ratio, Common Fraction, Single Line Fraction or Scale factorx -> 5x).
At least that's how it is in NX11. Wouldn't be surprised if they've changed it and failed to document it which part of that new Continuous Beta Testing Release.
Tim Flater
NX Designer
NX 11.0.1.11 MP8
GM GPDL 11-A.3.3
Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
