Rotation of object - ANSYS APDL
APacheco
4
Good afternoon!
I am working at ANSYS APDL and i created a work plane at the plane YZ (Global axis). I created an object and changed to the cylindrical coordinate. Then, i Move/Modify the object and for DY i set to 45 degree. The object was rotated, but it rotated with respect the Global Z axis. I would like to rotate, for example, with respect the new WX or WY (Local axis).
Please, could somebody help me with detailed description of the steps to follow?
Thanks!
Hi APacheco,
For the cylindrical coordinate system, the rotation will be in the Z axis (second picture below).
Try first rotating the coordinate system using THYZ or THZX of LOCAL command before you move/modify the object.
Kind regards,
Jason
Hi Jason!
Thanks for your help. I tried to change the values of THYZ or THZX, but i did not have success. I used the macro below. It worked, but the rotation is about Global Z, i would like to rotate about WZ (Local Z). Could you help me?
/PREP7
WPLANE, 1,0,0,0,0,0,1,0,1,1
BLC4,0,0,5,10,0
BLC4,0,0,5,10,0
LOCAL,11,1,2.5,5,0, , , ,1,1,
CSYS,11, !Select the coord.
FLST,3,1,5,ORDE,1
FITEM,3,1
AGEN, ,P51X, , ,0,45,0, , ,1 !Select the area and rotate it using move/modify (rotation of 45 deg)
Thanks!
Hi APacheco,
Comparing the sequence for parameters, your specified command has THXY=THYZ=THZX=0. Note that AGEN works in the active coordinate system, not Working Plane coordinates.
[pre]LOCAL, KCN, KCS, XC, YC, ZC,[highlight #CE5C00] THXY[/highlight],[highlight #CE5C00] THYZ[/highlight],[highlight #CE5C00] THZX[/highlight], PAR1, PAR2
LOCAL, 11, 1,2.5, 5, 0,[highlight #CE5C00] [/highlight],[highlight #CE5C00] [/highlight],[highlight #CE5C00] [/highlight],1,1,[/pre]
The LOCAL command is edited below. Give this a try.
Code:
/PREP7
BLC4,0,0,5,10,0
BLC4,0,0,5,10,0
LOCAL,11,1,2.5,5,0, , , -90,1,1,
FLST,3,1,5,ORDE,1
FITEM,3,1
Dear Jason and Cheah!
Thank you a lot!
Thread close.
