K
kumaichi
Guest
Hi Everyone,
I'm new to the sheetmetal world and looking for some help with rip and edge cuts. Below is a picture of a sheetmetal part I'm trying to make. It's the base for a machine so that I can catch coolant. It's tilted toward the front so I can direct the spent coolant to a reseviour. It's only the first part, I still need to make the flat areas around the base.
Anyway, I started with a solid model because I couldnt' figure out how to make the part in sheetmetal so I just converted the solid to sheetmetal which worked suprisingly well. Now I have my sheetmetal pan but I need to insert rip and edge cuts so I can flatten it out.
I tried creating an edge cut and by selecting one of the edges leading from the top down to the bottom, seemed pretty simple, select the edge I would like cut. I get the following error:
Could not construct feature geometry.
Since that didn't work, I thought I'd try a rip cut along the base flat piece at the edge I was trying to select. I go into sketcher, draw my line from corner to corner and I get the same error.
Could someone please help a newbie to create the cuts to flatten my sheetmetal part?
Thanks in advance,
Craig
The part file can be found here in case I did something wrong:
2005-10-02_182835_Base.zip
Thanks in advance,
Craig
