Fatalxception
I have a 3 story building that uses the same steel brace size and configuration for it's lateral resistance(wind) from top to bottom, and has conc. floor diaphragms.
On the 3rd floor there is for example 3 braces (one on each end of the bldg. and one in the middle of the building).
On the 2nd floor, there is one at each end, one in the middle, and one that is added half way between the middle and one of the sides (say 30 feet from the middle brace).
At the first floor there are 2 at each end, one in the middle and one on each side of the middle (this time 20 feet away from the middle brace).
My question is will the diaphragm be able to distribute the accumulating force between all the braces equally on each floor or will the brace (for example the middle brace)which is lined up one on top of another, accumulate more force than the others as it would in a non rigid diaphragm?
