Hi. My first post here and this is actually my face project as an structural engineer, hope you can help me out.
I have this retaining wall L-stand. It needs to be designed for a loader to be able do drive up on to it and containers will be on the other side below it.
It needs to be 1,2m high and 22x6m. The filling and backfilling will be crushed rock. I have calculated with interior friction of 45. I am unsure about the surcharge load of the loader itself.
But lets say about 15 tons+loads of 6 tons The axels is about 3x1,5m: That means 4,5 tons/m2
This is what i get.
I used a slightly lower filling to compensate for the ramps negative angle. In this program i cant make the angle negative
SO this is actually the earth fail surface not the wall itself that is limiting?
This is what i get.
