I am trained as a mechanical engineer and as such am feeling moderately dumb when it comes to soil retention. I have a shared property line that is a slope and needs to be retained. There is also a pretty good possibility of having a fair amount of drainage along the top as well as the bottom of what will be the wall. The soil is, as far as I can tell from what I have read, heavy clay with a fair amount of rocks and gravel. The slope on one end is about 3 to 4 feet high, at the other end, 6 feet high. It is about 70-80 feet long. At the base at the shallow end, there is a storm drain.
It has been suggested that a rock/boulder gravity wall is the cheapest, which I can’t verify at this time, but someone else will do the work. I am very concerned about erosion behind the wall and along the base. What can be done in such a situation to keep the soil where it is and have a good, stable, long-lasting wall?
What are some of my other options in building the retaining wall? I am trying to keep the budget as low as possible.
Finally, having a good knowledge of mechanical engineering, is there a source where can I get some good practical learning on the design of retaining wall systems and earth retention and the necessary governing equations? Thanks in advance for the help!!
