Transient1
I've performed a response spectrum analysis and I want to make sure that the right procedure in post processing contact results is something like:
summtype,comp
/INP,,mcom
ESEL,S,REAL,# !Select Contact Target
FSUM,,CONT !Get reaction forces
I'm a little confused about when I would want to use COMP or PRIN on the sumtype command. This procedure doesn't give the results I would expect (effectively zero). I'm reviewing the model now and any insight into post processing the results would be helpful.
summtype,comp
/INP,,mcom
