I have designed and built a 2 kW, full-bridge, dc-dc converter.
As part of this conveter, I have a double-sided PCB board that contains the control/driver circuitry and the four power switches. I have three separate copper pours that each create a local ground plane for the control circuitry, the drivers and the MOSFETs respectively. These three ground planes are connected together at a single point, where the power enters the board. I have three separate power tracks that run to each of these three areas to provide the dc voltages. The dc voltages for the control and drivers is 15v dc, and the dc voltage that goes to the MOSFETs is around 340v dc.
I have added an electrolytic capacitor (47uF-100uF) in parallel with a ceramic capacitor (0.1uF) between each of the three ground and power tracks that go to each area of the board, just after the tracks leave the single connection point where the power enters the board.
I thought that I had therefore put together a pretty good design in terms of removing noise and spikes from my low-voltage dc supply tracks. I do also have local decoupling of all the chips using a ceramic capacitor next to the chips.
However, when I turn on my system which is switching several amps at 100 kHz, I get some really unpleasant spikes on the 15 dc supply tracks at around 7-10 Mhz, relative to the local grounds... I would have expected my electrolytic/cermanic capacitor combo to sort out the problem...
So, I guess where I am going wrong is in my choice of capacitors, both in terms of value and ESR....
My question is this... If I wanted to formally work out what decoupling capacitors to use to remove/reduce the spikes on my low-voltage dc-spply, how should I do it?
Thanks in advance.
Best regards,
BPELEC.
