Removing Showroom Environments NX2
Booga
New member
Aug 2, 2006
5
New to this forum so this may have been asked before.
Is there any way to remove the showroom environment once it has been added to a model. I am trying to produce photo-realistic pictures with white backgrounds, for a document.
Unfortunately the model has had a showroom environment added to it and even though you blank all walls it is still affecting the backgroung colour.
Thanks,
Paul
This can be done in one of two places. You can either select the "Remove All Walls" option on the Edit Envrionment Cube Image dialog (it's about 3/4 of the way down the dialog), or you can go to the Visualize Shape toolbar and toggle OFF the icon labeled "Show Environment Cube". If the "cube" is not being displayed, it should not interfer with any other visualization operation.
John R. Baker, P.E.
Product "Evangelist"
NX Product Line
UGS Corp
Cypress, CA
Phone: 714-952-6032
FAX: 714-952-5758
John.R.Baker@ugs.com
Thank you I will give it a go.
