I have a RC beam that is bearing on a wall at one end and integral with a column at the other. I could design the beam as partial fixed to the column and pinned at the wall. To make reinforcement placement simple, I was thinking instead to design the beam as pin-pin so it will mainly just have bottom bars. I don't have to worry about the integrity of the column to beam joint either.
I know the beam will work this way, however I am a little concerned with the cracking that will occur at the top of the beam at the column end as this end rotates to achieve a "pin" condition. Anyone else have experience with this situation? Should I add a few top bars at this end anyway to control the crack width?
