dreinert
- Feb 19, 2009
- 2
I am try to figure out how to find the impact force that a Recip saw (Sawzall) can exhibit.
To better understand:
If you took the blade out of the saw and just used the reciprocating rod (.5" Dia) was held 1 inch off a block and then the trigger pulled so the shaft smashes into the block.
I had asked a friend of mine in materials and he thought you could use:
Power=Force*Velocity=Current*Voltage
And measure the peak current of the saw. Does this make sense?
Thanks for your help.
dreinert
dreinert
