Reciprocating Compressor valves moved during Depressure Step
10815L
Chemical
Jul 24, 2011
178
HI,
May be one of the from member can explain the reason and consequence of valve moving during depressure step of a aerial reciprocating compressor .before starting.
10815l
This allows you to start without a gas load by holding the cylinder suction open.
What is the benefit by starting it without load.
10815L
The driver does not need to be capable of Full Load torque at start-up, if it was it would be larger than required for normal operating conditions.
