presFEM
Aerospace
- Jul 9, 2003
- 2
Hi everyone,
I have defined a CTE (ALPHA) for the RBE2 element identical to the supporting structure but it expands in an unexpected manner and is failing the thermoelastic check. I am using MSC Nastran 2012.2.
Does any one know what could be happening?
Thanks in advance!
INIT MASTER(S)
NASTRAN OP2NEW=0
ID M,MSC
$SOL STATIC
SOL 101
TIME 10000
CEND
TITLE= THERM-ELAS CHECK
ECHO = PUNCH
TEMPERATURE(INIT) = 10
SUBCASE 1
$ DISPLACEMENT(PLOT) = ALL
SPC = 1001
TEMPERATURE(LOAD) = 100
DISPLACEMENT(SORT1,REAL)=ALL
SPCFORCES(SORT1,REAL)=ALL
STRESS(SORT1,REAL,VONMISES,BILIN)=ALL
BEGIN BULK
PARAM PRTMAXIM YES
PARAM,POST,-1
PARAM,OGEOM,NO
PARAM,AUTOSPC,YES $ORIGINAL MODEL
PARAM,MAXRATIO,1.E+8
PARAM, COUPMASS, 1
PARAM,K6ROT,10.
PARAM,GRDPNT,0
PARAM,PRGPST,NO
PARAM,PRTPCOMP,1
$ Elements and Element Properties for region : conm2.19
CONM2 9100001 100001 8 .2875 0. 0. 0.
0. 0. 0. 0. 0. 0.
PSHELL* 3 88888888 .03008 88888888
* 1. 88888888 1. 2.9
-.01504 .01504
$ Pset: "pshell.100013.22" will be imported as: "pshell.3"
CQUAD4 110303 3 110396 110397 110430 110429 5 0.
CQUAD4 110304 3 110397 110398 110431 110430 5 0.
CQUAD4 110305 3 110398 110399 110432 110431 5 0.
CQUAD4 110306 3 110399 110400 110433 110432 5 0.
CQUAD4 110307 3 110400 110401 110434 110433 5 0.
CQUAD4 110308 3 110401 110402 110435 110434 5 0.
CQUAD4 110309 3 110402 110403 110436 110435 5 0.
CQUAD4 110310 3 110403 110404 110437 110436 5 0.
CQUAD4 110334 3 110429 110430 110465 110464 5 0.
CQUAD4 110335 3 110430 110431 110466 110465 5 0.
CQUAD4 110336 3 110431 110432 110467 110466 5 0.
CQUAD4 110337 3 110432 110433 110468 110467 5 0.
CQUAD4 110338 3 110433 110434 110469 110468 5 0.
CQUAD4 110339 3 110434 110435 110470 110469 5 0.
CQUAD4 110340 3 110435 110436 110471 110470 5 0.
CQUAD4 110341 3 110436 110437 110472 110471 5 0.
$ Referenced Material Records
$ Material Record : mat2.100100013
$ Description of Material :
$ DUMMY ALU FOR THERMO-ELASTIC CHECK
MAT1 88888888 70.0+9 26.9+9 1.0-5 0.0
$ Multipoint Constraints of the Entire Model
$ ID conflict : the PATRAN MPC ID was 9100001
RBE2* 9900017 100001 123456 110430
* 110437 1.0-5
$ Nodes of the Entire Model
GRID 100001 -.185235-.13512 -.0125
GRID 110396 -.16667 -.202685.01504
GRID 110397 -.16667 -.18767 .01504
GRID 110398 -.16667 -.172658.01504
GRID 110399 -.16667 -.157644.01504
GRID 110400 -.16667 -.14263 .01504
GRID 110401 -.16667 -.127616.01504
GRID 110402 -.16667 -.112603.01504
GRID 110403 -.16667 -.097589.01504
GRID 110404 -.16667 -.082575.01504
GRID 110429 -.185235-.202685.01504
GRID 110430 -.185235-.187671.01504
GRID 110431 -.185235-.172658.01504
GRID 110432 -.185235-.157644.01504
GRID 110433 -.185235-.14263 .01504
GRID 110434 -.185235-.127616.01504
GRID 110435 -.185235-.112603.01504
GRID 110436 -.185235-.097589.01504
GRID 110437 -.185235-.082575.01504
GRID 110464 -.2038 -.202685.01504
GRID 110465 -.2038 -.187671.01504
GRID 110466 -.2038 -.172658.01504
GRID 110467 -.2038 -.157644.01504
GRID 110468 -.2038 -.14263 .01504
GRID 110469 -.2038 -.127616.01504
GRID 110470 -.2038 -.112603.01504
GRID 110471 -.2038 -.097589.01504
GRID 110472 -.2038 -.082574.01504
$ Loads for Load Case : Untitled.SC1
$ Displacement Constraints of Load Set : spc1.1001
$ Referenced Coordinate Frames
CORD2R 5 0. 0. 0. 0. 0. 1.
* 6.12323-17 1. 0.
CORD2R 6 .3765 -.548 -1.106 1.66696 -.548 -1.106
.3765 .742462 -1.106
CORD2R 7 -.3765 -.548 -.01 -1.3765 -.548 -.01
-.3765 .452 -.01
CORD2R 8 0. 0. 0. 0. 0. 1.
* 6.12323-17 1. 0.
SPC1 1001 123456 110464
TEMPD 10 0.0 100 100.0
PARAM,LSTRN,1
ENDDATA 00c02c0a
Thanks in advance!
INIT MASTER(S)
NASTRAN OP2NEW=0
ID M,MSC
$SOL STATIC
SOL 101
TIME 10000
CEND
ECHO = PUNCH
SUBCASE 1
SPC = 1001
BEGIN BULK
PARAM PRTMAXIM YES
PARAM,POST,-1
PARAM,OGEOM,NO
PARAM, COUPMASS, 1
PARAM,K6ROT,10.
PARAM,GRDPNT,0
PARAM,PRGPST,NO
PARAM,PRTPCOMP,1
0. 0. 0. 0. 0. 0.
-.01504 .01504
* 110437 1.0-5
* 6.12323-17 1. 0.
-.3765 .452 -.01
* 6.12323-17 1. 0.
PARAM,LSTRN,1
ENDDATA 00c02c0a
